so i though it was fine time to build some decent sliders and rebuild the standard belly plate into something stronger.
so i came up with the following.
ill get some more photos of it all mounted up when i was me truck. there is also another plate that goes from the rear most front suspension link back to the transfer case cross member.
all built with a stick welder, grinder and a plasmer cutter on the drive way
