5L 3ltr transplant into LN61
Hi has anyone fitted a 5L 3ltr into a LN61? I'm just wondering what problems I might encounter. Any advice greatly appreciated.
Re: 5L 3ltr transplant into LN61
try using the search function
I've got a 5L in my LN65 Hilux, went in sweet as, same engine mounts as the old 2L. The clutch and flywheel are different, the 5l flywheel has 8 bolts and is a 9.5" plate i think where as the 2L was only 6 and 9". I also used a later model bell housing but in hindsight I probably could have stuck with the 2L one, never tried it for fit.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
Thanks. Did you turbo yours?
Also how did you deal with different flywheel/clutch?
Mines not turboed.
I just used the 5L flywheel, and put a new clutch on it
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
