After easter I thought maybe a few of you will be wanting to put pics in the forums for your trips. here is the easy way to do it
How to get the URL (address of pic) for the pic you want from your album. Find the photo you want in your album by going to it. right mouse click the photo -> goto properties -> then select/copy the URL/address you should see something like this address -> http://www.offroadexpress.co.nz/images/ ... .sized.jpg
now use this URL with the following post instructions on insert a photo in your post and your away laughing.
When writing your post click the "Img" button just above where you type, then write/paste your URL for the pic and then click the button again. has to have the http:// for it to work.
If you want to just put the code in manually enter this without the white spaces. " [ Img ] http://URLHERE [ /Img ]" I put the white spaces in otherwise it would think I'm trying to put a pic in
Photos in the forums - easy as pie
You open the picture up to its biggest size in your album and right mouse click then select properties.
See the bit i highlighted there in blue, you copy that bit and paste it in between the image tags like this:
[img]xxxxxxxxxxxpasted%20bitxxxxxxxxxxxx[/img]
