Hey i have a LN130 89 hilux surf with a 2.4LTD motor in it.
When im driving just say down the road and i boost it (green light comes on) the motor will stall if i push in the clutch or stop. Then i have problems starting it. Unless im in gear and it will start straight away. Also if i dont use the turbo whilst driving its fine.
Can someone please help Thank you.
Turbo problems
Re: Turbo problems
auto or manual?
sounds more like a electical fault or fuel starvation issue to me as it runs fine when not demanding so much fuel.
when a turbo stops working...its stops working. there's no in between
J____A____Y
- Stropper
Re: Turbo problems
It's a manual.
Yea have tried diagnostics but nothing showed up.
J____A____Y
- Stropper
Re: Turbo problems
Hey bud replaced fuel filter now runs perfect thank you very much
