Hey guys, my mate has a 97 Pej 3.5 180000km, swb for sale. He bought himself a cruser, so paj is extra.
However it has idle issues surges at stand still, stalls at traffic light too, both of these are intermittent.
Is this an easy fix and a good buy?
Pajero 3.5 Purchase
Re: Pajero 3.5 Purchase
usual the TPS ensor , and dizzy cap and rotor casue that . i had the same problem . replaced dizzy cap and rotor then all gone
Hey, Thanks for that. Will have a look, is the TPS difficult and expensive to replace?
dont know , i didnt replace mine .. but i would say a local wreaker would have one
Bolo wrote:usual the TPS ensor , and dizzy cap and rotor casue that . i had the same problem . replaced dizzy cap and rotor then all gone
Doesn't have a dizzy or rotor.
Try the idle stepper motor. They get gunked up and don't work as they should. Under the throttle body - take to it with carb cleaner.
Once you've pulled the idle control valve off, and cleaned it, check the coil resistance with a multimeter:
[ a ] [ b ] [ a ]
[ c ] [ d ] [ c ]
a-b, and c-d should be something like 27 - 33 ohms.
The idle stepper motors can get water in them too and rust out. There's three screws on the end of it you can remove and pull the end of off and have a look inside.
[ a ] [ b ] [ a ]
[ c ] [ d ] [ c ]
94 Pajero SWB, 3.5 V6
Thanks will do that, where do I get a cheap replacement if it is faulty?
- Moriarty
Werner wrote:Thanks will do that, where do I get a cheap replacement if it is faulty?
Mitzi agents is a good place to start. Hold on to your wallet!!!
Go to the private messages and edit your profile, put in the city or locale, make it easier to give advice as WHERE to look for stuff.
