eliptcial spring into a Terrano
long
Post by long »
Has anyone one on the message board done this mod to a terrano if so Im me me or e mail longnitemals@gmail.com.
Im looking at doing it to my 2 door one so i can get more hight n bigger round black things under it.
TNX in advance.
Terrano TD 2.7 and a ssangyong Rexton
DieselBoy
Re: eliptcial spring into a Terrano
Post by DieselBoy »
Have you ever stuck your head under your Terrano and had a look at what sort of springs it has??
I think you will find the rear is coil sprung and the front is torsion sprung.
Either that or you have a very rare leaf sprung model??
If so, what sort of eliptical springs where you thinking??
You can get the following:
3/4 eliptical
1/4 eliptical
Full eliptical
What were you thinking??
long
Post by long »
I sure have had my head under the old girl n yup you r correct with the suspension system it has under it.
Im thinking of useing the likes of dare i say it cause i will have to go was out my mouth with soap toymota front n rear diffs with there orignal spring system so i can get some decent hight out of the beast because the orignal system sux big time for lifting it up.
SMOKEY
Post by SMOKEY »
Hi Long, when you ask about fitting Elliptical Springs, do you mean to the front to replace the torsion bar set up ??. If you look in Forums, Projects/Mods 3/4 down first page kbjj (Jeremy) has a build thread of his Navara showing what can be done. You already have coils on the rear that I am sure with a bit of tuning can be made to work better. As you will see in Jeremy's build it's not cheap but he has a very capable vehicle mind you he is a very capable Electrician that is not bad as an Engineer :wink: , mind you he was taught by NIBBZ :shock: ,just didn't inherit his slow build genes :oops: . And as NIBBZ would say,
CHEEKY FAWKER,
FITZY.
long
Post by long »
Giday smokey im thinking more of replaceing both ends with them im tired of coils n torsion bars
Return to “Tool Shed”
