LN61 Gearbox removal
FORGE1
Post by FORGE1 »
Hey everyone,
This is hopefully just a quick question to save time as Im restricted to 1 hr a night to work on the lux. Bosses orders haha.
engis is: 2.4 non turbo diesel
Im replacing the clutch and so far have removed all bell housing bolts bar the top 2, the sway bar, the clutch cylinder, both driveshafts, undone any exhaust brackets that are in the way, and started on the cross member bolts.
My question is: is there anything else that you can think of that will need to be taken off or moved before I go any further?
and will I need to take the gear leavers off for the removal? (I did with my bighorn but not for my safari in the past)
Thanks in advance for any help
Ray
GotFlex
Re: LN61 Gearbox removal
Post by GotFlex »
Yes take gear levers off. and make sure you have disconect the speedo cable and reverse and 4x4 light switch wires.
FORGE1
Post by FORGE1 »
GotFlex wrote:Yes take gear levers off. and make sure you have disconect the speedo cable and reverse and 4x4 light switch wires.
Sweet cheers I knew there was something else I forgot.
Ray
