nissan safari steering
Hi im have trouble with my Safari 1994 done 300kms aprox drifting while the steering weel is not moving. have being told it could be the steering dampner or control arms has any one got a better answer and its not the Bozs
- safaripete
Re: nissan safari steering
bullivant wrote:Hi im have trouble with my Safari 1994 done 300kms aprox drifting while the steering weel is not moving. have being told it could be the steering dampner or control arms has any one got a better answer and its not the Bozs
does it have any lift?
is it slowly moving side to side or shaking quite bad?
Just have a feel around with a bar to see if theres slop anywhere ie wheel bearings, kingpins, panhard bushes. I'd also check the front bushes on the radius arms to make sure they aren't collapsing or gone already. When you lose correct castor you can end up chasing it a bit with the wheel to keep it goin straight.
Also check all the tie rods are straight if you've offroaded it I guess.
