just trying to get hold of the guys in levin who have been doin this conversion, i think they came down for the kiwi challenge last year.
does anyone know how to get in touch
cheers stu
fitting commie v6 to bighorn 5speed
DIRTY OLD HILUX
022 519 7700
022 519 7700
Re: fitting commie v6 to bighorn 5speed
Im fairly sure its just the transfercase they use. The splines are the same in the bighorn transfer as the commy auto. Makes for one hell of a long combo tho
use commie motor
, make a flywheel for it,
use the commie auto flexiplate to balance the motor,
use commie starter
use the big horn bell housing, make a adaptor plate between the commie and the bell housing, make sure you dowel it tru to the crank or u will rip out the clutch center
use bighorn or commie clutch which ever is stronger,
cut bellhousing to make the starter fit.
use the bighorn gearbox and transfer case
cant remember the mounts
that should cover it
use commie starter
nice one pedro. cheers for that
DIRTY OLD HILUX
022 519 7700
022 519 7700
i have tranfer and adaptor plate to bolt to a holden auto made by guy in levin i want $550 for it
