i have just finished with the help of 4wd acc my suzuki with vn motor and 91 nissan safari axles etc would like to know how i could do the handbrake if i could modify rear end at all
any help would be great thanks
handbrake
Re: handbrake
Just doing mine and using mu calipers,they are a tight fit on a worn rotor but can make them work.If you can find a hand brake style caliper to fit a 18mm rotor that would be the way to go or like me just use what you can find.Simple bracket to make and they just bolt on.Can supply a pic for mu style calipers if you want.Havn't sorted the cables yet.
Re: handbrake
oh sweet a pic would be good if you can thanks
il check out
.some mu calipers
.some mu calipers
Re: handbrake
gday sent you the fax num 033127691 if you could fax that temp plate thr that would be great cheers
