Hi all,
My flatmates 3.1td wizards alternator crapped out recently, so we replaced that, but all the light were staying on on the dash and the heater etc wouldn't work, so he bought a new charge relay for it.
Heres the problem: We can't find where it goes!
The one he bought is blue and we can't find any blue ones for it to replace, let alone a slot for it to fit into in the fuse box as it seems to have more bits poking out of it (if you get what i mean) than any other relay, leading me to believe the charge relays hidden in an obscure place.
Any ideas much appreciated
Dean
Wizard charge relay
- Suza
Re: Wizard charge relay
If it is the same as a 3.1 Bighorn try the left hand side of the engine bay behind the battery there should be a black case mines in there.
Yea we found that, but the writings all in japanese so have no idea where it goes
should be the same colour. and it only fits the one slot.
pull each one and compare.
not much fun doing those alternators.
pommie al wrote:should be the same colour. and it only fits the one slot.
Thats what i thought, but theres no blue one in there at the moment and it doesn't fit any of the slots.
Starting to think there may be 2 different ones as there is one brown relay in there..........
- george.ene
- Driver/Navigator
Im in hoon hay. just replaced mine. i wont have my car till wednesday (at panel and paint) but you're welcome to come have a look at mine then.
arnt the later model wizz's Different give gavin a ring on 0276749347
he will be able to clarify for ya
original post was 18 months ago.
but just incase dean zuk's flatmate still hasnt changed the relay
its the brown one in the fuse box, so if you have a blue one you may need to exchange it
some are blue and some are brown
- george.ene
- Driver/Navigator
I have a spare sitting around. will do it cheap
Oh wow this was a while ago.......................................
Yea he got it exchanged it was the wrong colour
