Not sure what its worth so just testing the water and open to offers, wanting a double cab ute prerebly a Nissan Navara.
Mod list inludes
-Sas with hilux axles front and rear with IFS wide axle setup
-4.8 diffs, lokka in the rear and open upfront
-2.8 4jb1 Engine running 16psi boost, just recently had compression check and injectors and all tuned properly by hastings diesel shop and all nuimbers are good
-disc brakes on the rear
-Winch is 9500 trail gear, used twice
-tires are 35" Maxxis Trepadors on 15x10s
http://www.offroadexpress.co.nz/4wds/19 ... omment-221
lots of work been done to this truck and built by a reputable engineer all certed wof and reg
