i pulled the cooler off and dark fluid dripped out, then i put the hoses into a bucket and turned engine on, it then pumped out dark fliud so not blockage in that pipe or hose and it filled half a bucket which meant the auto had not run dry.
Next pulled the drain plug, dry. Filled back up with fluid hooked up the in hose to the cooler turned engine on and fluid pumped out fast, cooler not blocked. Hooked cooler out hose back up and all feels fine no new noises from the auto then went to aotea block with no problems
apart from getting stuck
, blowing the diff lock fuse,two spot light fuses and the central locking
where in welly is a good place for gauges? i want an electric oil temp gauge.
