Transfer case swap 249 to 242
Just scored a 242 case from a 96 XJ for $200 now time to throw out the 249 full time 4wd case...
Re: Transfer case swap 249 to 242
Make sure the input shaft is the right one, .840inch. If it is then all the wiring should be in the correct spots too.
http://www.offroadexpress.co.nz/Forums/ ... 32&t=25800 for any reference assistance.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
xj wrote:Make sure the input shaft is the right one, .840inch. If it is then all the wiring should be in the correct spots too.
Sure is the .840 just measured it now..
how did ya get on?
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
