I had wee search but nothing usefull.
I have a hilux with LSD rear taht im wanting to shim up.
Any one have any info on this? Or even step by step instructions,
Sorry never really played with diffs.
Thanks
shimming lsd
Re: shimming lsd
put a large washer on top of the spring then reassemble. remember to clean the shims well before reassembly.
Re: shimming lsd
Sweet do ya know what kind size washer?
Diff has 109ks since new from toyota. So plates etc sould be mint.
Re: shimming lsd
This info is from an old Forum .
8" Diff breakaway is much the same as the 9.25" Diff
From memory the 9 1/4" diff , standard, has a breakaway of 70 to 90Ft Lbs. By trying differant thicknes's shimms you will reach tour required target. Go no more than 1/2mm at a time ,
I have got an old axle, cut it off to 6" long(splined end) and welded an old 1/2" socket to it , fit it into your diff side gear, then install your touque wrench, fit another old axle to the other side, which is held in the vice.
NOTE Breakaway or cracking , is the energy level to start the movement of turning the axle.Which is far greater than the flowing resistance.
Kevin
Kevin
Re: shimming lsd
I don't do washers.... I've got a slippery housing here where an idiot did this and got it wrong and it has blown one end of the housing out
I clean off the packs stack them up and measure the thickness (measurement is in the hane's manual) and then cut shim steel to make it back out to the tight side of the measurement, drop these under the first drive plate, sit's in the bottom of the housing and reasemble.... remember to turn your spring retainer in the centre so its lined up right... seen a few broken ones from this
I don't do oldblues trick.... in fact its the right way to do it its just I don't have a jig like he's got, one day when I've got some spare bits
Cheers Reece
Cheers Reece
