My actuator is @#$%ed and I need to replace it.
Any help would be appreciated.
Finn
Wanted - Centre Diff Actuator for 95 Hilux
Re: Wanted - Centre Diff Actuator for 95 Hilux
Stick up a pic of the bit you need, I may have one from when I replaced my transfer case.
- safaripete
is it the same as a 99?
my boss replaced the gearbox and transfer and still has it sitting at work
pic would be good
pic would be good
Thanks guys. Don't know if it's the same part as a 99 but here's some links - pic uploading doesn't work.
http://www.flickr.com/photos/64770849@N ... hotostream
- safaripete
will have a look at the box
looks to be similar
where are you located in nz??
looks to be similar
safaripete wrote:will have a look at the box
looks to be similar
I'm out. I wanted to make sure you needed the actuator motor and not some relay rods. My spare did not come with an actuator
looks to be similar
Fingers crossed...
If you could take a pic of it or note the part number I'll make sure its the right one. If so, let me know how much you want for it. I'm in Aucks so will pay freight as well.
Finn
Got hold of one and while its fixed the fault with 4WD engaging, there's still a fault with the 4x4 lights constantly flashing.
Here's my new post about this http://www.offroadexpress.co.nz/Forums/ ... 22&t=26485
