SOA a Landcruiser
92 safari 17
SOA a Landcruiser
Post by 92 safari 17 »
Hey all
I have been searching the forums for info on whats involved in doing a SOA conversion on my 70 series cruiser,
the search has brought up a few things but were just peoples opinion about doing it, can anyone tell me exactly whats involved?
Or is there a Workshop in hamilton that could do it for me? or some one who may be able to do it?
jonossiksilvia
Re: SOA a Landcruiser
Post by jonossiksilvia »
another person posted this a few days ago. check the toyota section pretty sure was in there
Fakey
Post by Fakey »
First question, Why do you want to do a spring over :?:
Didn't barbie drive a jeep??
92 safari 17
so i can run the 37s i want and gain clearance, but still keep the good flex of my stock springs
H2OLOVA
Post by H2OLOVA »
go for it. It makes a big difference to where they'll go without getting caught up on the springs. And just so ya know my avatar pic was taken before i did the SOA on mine :oops:
Link here http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=4&t=26504
MNC
Post by MNC »
92 safari 17 wrote:Hey all
Hey, I've got a 60 Series rear diff that has the spring perch's cut off and welded on top of the diff housing if your interested?
Had been planning on listing it on trademe for sometime now.
callum007
Post by callum007 »
not much involved. whip the diffs out, axe the spring perches off or make new ones. weld back in at correct pinion angles and obviously in the right place, will need high steer conversion too.
do a body lift while your at it, extended shackles.. you'll never tip it over!
niblik
Post by niblik »
callum007 wrote:not much involved. whip the diffs out, axe the spring perches off or make new ones. weld back in at correct pinion angles and obviously in the right place, will need high steer conversion too.
have a looky at these pics of one done.. isnt that right callum? http://rides.webshots.com/album/5543104 ... E?start=12
92 safari 17
Cheers for the feed back guys,
I was talking to performance mechanical here in taupo today and we decided to do a coil conversion with my old gq patrol diffs and arms ect got a quote of $1500 for labour if i supply all the bits to complete conversion + cost of cert after wards :D
callum007
Post by callum007 »
Geez thats an old photo. I had taken out the shackles by then.
jakwoo39
Post by jakwoo39 »
i know this is posted on an opposition site but ih8 mud has a step by step guide on how to do the SOA with everything from steering to shocks
http://www.ih8mud.com/tech/soa/index.html
its for a 40 series but most things will be much the same
Fakey
Post by Fakey »
Hmm what condition are your axles in? After being burnt out id imagine all the seals an bushes are all stuffed. These can be very expensive to replace.
Also your patrol rear diff head is centered an the cruiser transfer case is offset to the right (sorry for stating the obvious if ya already know this), if ya use the patrol rear diff itll probably cause bad driveline vibrations
wopass
Post by wopass »
Fakey wrote: if ya use the patrol rear diff itll probably cause bad driveline vibrations
why? because its offset? thats what UJ's are for dude :wink: do you think the driveshaft knows its up or sideways offset?
Return to “Tool Shed”
