WTB - Custom or new model factory Landcruiser Fuel Tank
MNC
Post by MNC »
Hi All,
I have a feeling the fuel pickup inside the fuel tank of my FJ40 is nearly blocked (after having blamed my dizzy :oops: ). It is the later model that sits under the body and will be taking it out soon to inspect.
I would be keen to replace it with an aftermarket tank to sit on top of the rear tub, between the wheel arch's.
Does anyone have, or know of a second hand one for sale? Or maybe a cheap place to get one made up?
Alternatively, if that proves too expensive I may be in the market for a good condition second hand factory one if anyone has one of those?
Thanks,
ClassicCruiserSpares
Re: WTB - Custom or new model factory Landcruiser Fuel Tank
Why not buy a plastic fuel cell? there not too badly priced and easy to fit!!
So does this mean the dizzys all sweet? :D
niblik
Post by niblik »
clean and or replace said pick up? possibly flush tank and inspect?
MNC
Post by MNC »
niblik wrote:clean and or replace said pick up? possibly flush tank and inspect?
Yeah, this is probably my first option - cheap and fast. Although I'm expecting that its probably blocked by rust?? So would need to replace tank anyway.
If its just dirt then I'll run with what I've got but future mod is in mind... Rear mounted winch - and the underfloor tank sits right in the way!!! Could kill two birds with one stone by replacing it now.
There was one on trademe not so long ago that I'm now kicking myself that I didn't buy. :(
MNC
Post by MNC »
ClassicCruiserSpares wrote:Why not buy a plastic fuel cell? there not too badly priced and easy to fit!!
Plastic is not a bad idea. Who sells them?
I'm hoping its not the dizzy. Tested the power feed - At dizzy - 12v with key on, 14.7v at idle, and 14.8v on rev. I'm assuming that sounds sweet so not a power feed issue?
While plugging the multimeter in we noticed the fuel filter wasn't full of gas. So disconnected line at the carb and pressured the fuel tank and no fuel came through, same again in front of the filter and no fuel came through so seams like it might have been getting enough to idle but couldn't suck enough fuel on rev...
Connected a funnel up to filter and filled it with gas. It seamed to rev better but was pinning pretty bad which I'm now hoping is just timing.
Next plan is to clean out the tank, and redo timing and keep fingers crossed that is what the issue is :!:
PS. Two pumps of the accelerator completed drained the fuel filter of gas :shock: Thirsty beasty :twisted:
Good to hear your making progress, the power supply sounds good could be a tooth out still and cap on wrong way but you wont know till the fuel issues are sorted but your heading in the rite direction. Good work.
V8 shops have the plastic tanks or performance car places have them.
muddy
Post by muddy »
Got a tank here in Blenheim - under-floor version from a 1983 FJ40. Yours for $50...
MNC
Post by MNC »
Yeah, that is sexy but wont fit my newer model tub. Bit out of my price range anyway...
MNC
Post by MNC »
muddy wrote:Got a tank here in Blenheim - under-floor version from a 1983 FJ40. Yours for $50...
Thanks Muddy. I'll try an drop the tank out of mine tomorrow and if its full of rust I'll take you up on that offer.
Cheers, :mrgreen:
What fuel pump are you using? Stardard or an electric one? you may need to look at that too if you tank was rusty then no doubt the pump could be getting blocked or buggered too.
MNC
Post by MNC »
ClassicCruiserSpares wrote:What fuel pump are you using? Stardard or an electric one? you may need to look at that too if you tank was rusty then no doubt the pump could be getting blocked or buggered too.
Just the standard mechanical one.
It seamed to suck the gas through really well when we rigged up the funnel of gas on the in-feed of the fuel filter so I'm guessing the pump is working ok?
MNC
Post by MNC »
Thanks to the comments of ClassicCruiserSpares I've decided to go plastic.
Thanks for the offer of your Tank Muddy but I wont be needing it now as I've just bought this:
$70 of trademe and local pick up so pretty happy with that. :mrgreen:
Dimensions are pretty good for the rear tray (which I might modify a little to take this). 80ltrs so should keep the thirsty truck running all day :lol:
Hope I can make it work :roll:
Anyway, shouldn't be any rust issues with it. :wink:
Nice one, thatll be perfect :wink:
niblik
Post by niblik »
good shit fella... looks the goods and will be great lookin towards longevity too.. nice.
so whats the go now? should be good to go or................?
MNC
Post by MNC »
niblik wrote:good shit fella... looks the goods and will be great lookin towards longevity too.. nice.
Cheers Guys,
Yeah, hopefully.
I'm going to cut a hole in the rear tub to recess this tank a little. Plumb it in, do the timing again and hopefully that's it (fingers crossed),
Got some other cosmetic stuff that I want to do as well while its all clean, but the truck should be driveable soon, :mrgreen:
MNC
Post by MNC »
Got the tank out tonight. snapped three bolts in the process :x And damn there was alot of mud on it :!:
Tank internals were clean as a whistle, no rust or dirt at all, and the intake was completely fine :x
Blew through the fuel line and no blockages :x
Fuel pump to come off next...
