brake adjustment
For all Nissan related topics
te_rarawa
brake adjustment
Post by te_rarawa »
any one have a good idea on how to adjust rear drums up on a nissan navara d21 4wd. im having a prick of a time everything is in the way and cant get a good rythem going when adjusting. do these have a special tool to use or do they autommatically adjust when you pull up hand brake or something???? any help would be good
FORGE1
Re: brake adjustment
Post by FORGE1 »
If its just like you standard drum brakes there should be an adjuster on the inside/behind of the drum at the bottom there will be a rubber bung (some dont have them as previous person may not have put them back). you will just need to take out and use a screw driver to adjust it. You will need to do this on both sides and make sure that its done evenly. I just did my handbrake ones on my bighorn and it was pretty easy and it is the same setup on my safari.
te_rarawa
Post by te_rarawa »
yea i know where the adjuster is there just seems to be no room to get a screw driver in there and constantly turn the adjuster. the whole is right behind the u bolt on the springs. maybe the adjuster is just worn i better take drums off to have a look.
