lower gearing for sj410b
For all Suzuki related topics
rumble11
Stropper
Post by rumble11 »
hay there just curious on my options for getting lower gearing for my sj410 im running tractor grips and by jesus they can get some placed but unfortunately i tgot stuck in a real clay bog hole and got totally bogged cause the truck couldn't turn the tyres?i have the model with the front disk brakes and 4wd light on the transfer case.is it possible for me to get a 413 transfer case and do a roklobster?or am i better of buying a gearing kit for over the states and installing those?
UBZ
Re: lower gearing for sj410b
Post by UBZ »
a rock lobster or 4.16 gear ser is made from cutting and welding half 413,half 410 counter gear together. and then mix and match some gears .
. machining of the hardened gear is expensive ,due to cutting head use .
But you have the hard part find , the 84 410 transfercase, so proborbly a bit cheaper than imported gears.
rumble11
Stropper
Post by rumble11 »
UBZ wrote:a rock lobster or 4.16 gear ser is made from cutting and welding half 413,half 410 counter gear together. and then mix and match some gears .
But you have the hard part find , the 84 410 transfercase, so probably a bit cheaper than imported gears.
cool mate thanks for that.so will any 413 transfer case do?im not really mechanically minded when it comes to transfer gears etc.is there any one out there that specializes in doing these mods?and if theres any one out there that wants to part with a transfer case ready to go bolt in owl be keen to purchase it.thanks
zukmeista
Post by zukmeista »
Or you could sell your current transfer case as they are quite desirable (I'm looking for one) and buy some transfer gears from the US. This would give you a greater range of gearing options to choose from depending on what size your tyres are. :wink:
rumble11
Stropper
Post by rumble11 »
zukmeista wrote:Or you could sell your current transfer case as they are quite desirable (I'm looking for one) and buy some transfer gears from the US. This would give you a greater range of gearing options to choose from depending on what size your tyres are. :wink:
if i do that that means owl have to buy another transfer case?. i thnk my best option will be to mix and match gears and make a roklobster?just need a contact to find out who could make it for me now???
suzookyman
Post by suzookyman »
If you decide to do the rocklobster I have a 413 case here that I need
to sell to fund other things just pm me if you want it.
suzookyman
They are around, one just sold recently on T/ME for $90.
zukmeista
Post by zukmeista »
Not with a light switch though :roll:
suzookyman
zukmeista wrote:Not with a light switch though :roll:
yes it did, haha your loss. (oh and iv got one and no you can't have it! )
zukmeista
Post by zukmeista »
:? I don't care, Ill just buy gears from the US when I can afford it.
rumble11
Stropper
Post by rumble11 »
is there any one out there that knows of any one that can do the machining and welding of the gear needed for a rock hopper transfer case?i have just picked up a 413 transfer case so im going with a rockhopper 4.16 thanks
UBZ
Post by UBZ »
where abouts are you located ?
Any decent engineering shop should be able to machine and tig weld the gear together.
rumble11
Stropper
Post by rumble11 »
UBZ wrote:where abouts are you located ?
im located in gisborne.just fort it mite be easyer if i sent it to sum one that has done it before thats all
Return to “Suzuki”
