chassis Diferences
chassis Diferences
Hi im abit new to this modifying thing. I bought a rolled rn46 with a 350 chev in it thinking it would be a quick change over of cabs.(if i never heard the engine running i probably never would have bought it
) anyway since finding a new cab i have a new problem, the chasis is to bent to be straightened. I have sourced a yn67 chasis but cant find any info on differences in the chassis can anybody help me? i know im going to have to modify anyway as the mounts on the rn46 have been moved back 30mm and the x member the gearbox sits on is different too. Any help would be much appreciated.
Re: chassis Diferences
I've mounted an RN single cab onto a YN double cab chassi, (still got the chassi out back, I've just checked it) your dead right all six cab mounts have to move, from memory I cut the old mounts and the new ones off both chassi's mounted the cab on blocks of wood between the chassi and cab and then played with mounting and trimming the different cab mount outriggers till you get something that works then bolted them up to the body and welded them to the chassi
The gearbox and engine mounts your going to have to do anyway
Cheers Reece
Fixed posting area...
Oops
thanks heaps for that reece ill get stuck into it over the next few weeks and hopefully have it drivable soon
