swb rear drive shaft
has anyone else got excessive play in the splines of the rear drive shaft have two now with the same slop, Instead of getting them rebuilt may asked for a heavier duty truck spline installed instead
- mudlva
Re: swb rear drive shaft
coxsy wrote:has anyone else got excessive play in the splines of the rear drive shaft have two now with the same slop, Instead of getting them rebuilt may asked for a heavier duty truck spline installed instead
have you pumped the splines full of grease that will normally sort out any free play
yes but thats sort term fix, it really needs heavier duty splines, ie heavy truck
- mudlva
coxsy wrote:yes but thats sort term fix, it really needs heavier duty splines, ie heavy truck
what about a cruiser drive shaft they dont seem to have any problems
they are as heavy as a saf'' so they must be using better grade steel or some thing along those lines
will see what beattys driveshaft people can come up with
- mudlva
but hay they do do a good job
