can you turbo an escudo 1.6l
Ricky
Stropper
Post by Ricky »
can you turbo a 1.6l escudo engine? if so what turbo could i use and how much psi
taz01
Tazzles
Re: can you turbo an escudo 1.6l
Post by taz01 »
sure you can...... i just happen to have the perfect turbo sitting here t2 type $180 brand new.......
WARNING:
Big
Post by Big »
yip we have a chap in our club that has turbo'd his 1.6 escudo and I think he used 2 head gaskets to decompress it a little.. from what I have heard goes real well and hasn't had too many problems.. I could ask him how he did it..?
Big Will
Post by Big Will »
Yes, an easy engine to turbo.
5L+GT35@21psi= 223RWHP
5L+GT35@30+psi= 287RWHP....
Great tow Vehicle!
lincooln
Post by lincooln »
what does it need? just a manifold, fuel pump, computer, injectors? How is the best way to lower compression? Double head gaskets? different pistons? also what would you do about an airflow meter?
Just a few questions if any body has time to answer.
Lubrication Specialist
Lubrication Engineers
crazyclark31
Post by crazyclark31 »
in my experiance if you use a turbo on the smaller side and run a modest boost,ie standard you should be ok with having to do anything else(injectors,head gasket). Esp if vehcile is a thirsty one. A higher pressure fuel pump helps alot,as does and intercooler.
Have done a few cars in my boy racer days and found this works but you have to be conservitve.
taz01
Tazzles
Post by taz01 »
as above dude perfect turbo size sitting here
WARNING:
crzyfl
Post by crzyfl »
Turbo still for sale?
Is there a manifold that bolts up or is it a custom job.
What is required for the computer?
DISCLAIMER
