hay guys i have a d21 92 navara 4wd ute.
have recently found my transfer case has packed up. its making a good whine while driving underload and have pin pointed it to the case. now does any transfer case work off any d21 or will it have to be a certain model??? will one of a terrano fit??? and will one of an auto fit??? i just wanna get a transfer case and slap it in without any hick ups.
nate
navara transfer case
Re: navara transfer case
The transfer off an auto has a bigger input spline. I have fitted a v6 auto transfer case to my TD27t manuel, but needed to change the input spline over, which required splitting the transfer case. I know that the v6 auto transfer case has a stronger chain in it, thats why I used it.
Are you aware that the transfer case has a seperate oil fill and drain bung?
Hope this helps
Jeremy
Hope this helps
Jeremy
kbjj wrote:Are you aware that the transfer case has a seperate oil fill and drain bung?
Seriously?
Damz wrote:kbjj wrote:Are you aware that the transfer case has a seperate oil fill and drain bung?
Seriously?
Yes, at the back of the case, one above the other from memory and a shit of a place to access the top one too.
Ph 0212078472
Ph 0212078472
