cheers,scott
1JZ-GE in a hilux?
1JZ-GE in a hilux?
does anybody know if there is a bellhousing that will adapt the 1JZ-GE(2.5 DOHC crown engine) to a R150f or the R151F? or what type of plate is needed
cheers,scott
cheers,scott
From memory the 1JZ and 2JZ actually bolt up to an R154... the input shaft is the wrong length to just whack a 150 or 151 on it tho.
What you need is a locally made adaptor that bolts to the gearbox end of the A340 auto bellhousing for that motor and then you can bolt a G52 or W56 onto it... I am pretty sure the R150/1 adaptor would have to be designed as the guy who does them locally only has them for the G/W adaptor.
Good conversion... just finished a 2JZ-GE one in a Hilux, goes like a haunted S%$thouse
Steve
Steve
NFORCA wrote:a 1JZ should bolt up to an R152 box. Are you sure its not a 1GGE that you are talking about?
If the R150/51/52 box casings are the same as R154 (internals are) then they wont have seperate bellhousings.
R150's definitely have separate bellhousings.
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
