Hi All,
I have just recently top mounted my 1kz-te and need to know where the vaccums pipe go from the brown and black things to the throttle body etc.
I don't know where any of them go. If you could take pictures for me i wud apprieate it very much.
Vaccum line positions please HeLp!
Re: Vaccum line positions please HeLp!
Does this help.
http://www.toyodiy.com/parts/p_J_1994_T ... _1708.html
Would take photo's of mine, but most of the vac lines not used no Valves / butterfly's anymore.
Only the turbo pressure sensor.
Calvin
Calvin
thanks calvin! u are a legend! couple of questions. i removed my egr valve and removed my large venturi in the throttle body. do i need my smaller venturi?. and i also have a wire of my loom located at my oil filter, it has a loop terminal on it do you know if this is an earth? Also does it matter what direction the arrow on the cambelt faces and if so what is the correct one? anti clock or clockwise?. Cheers mate.
You don't need the smaller venturi, it was to control the egr gasses from memory.
As for the cam belt, here is a link to an online manual for the 1KZTE
http://www.ncttora.com/fsm/1KZ-TE%20Eng ... index.html
Calvin
Calvin
