Rear cross member captive nuts
- gary_in_nz
So ummm, I managed to break one of the captive nuts off from inside the rear cross member on my Safari. Any simple ways of getting it tacked back on or do I have a big date with a grinder and mig?
- mudlva
Re: Rear cross member captive nuts
are you able to get a bolt into the nut if so then die grind or drill a slot on either side of where the nut went and with bolt firmly into nut pull down back into its original location and spot weld through the two new holes on either side
- gary_in_nz
ahh true, yeah the bolt is still in it, shall give that a go i think, thanks for that idea.
