warn winch
- mud_slinger
warn winch
so i picked up a nice 2nd hand warn winch and just in process of chucking it in.
i don't have a wiring diagram and i have 3 wires that go on 3 diff terminals labelled f1 f2 f3. what wire would go where? i am guessing that the 2 long wires the same length would go to batt but the 3 other ones the same length i have no clue.
also the solenoid box is pretty big and is not sealed. where is the best place to mount this and does it matter if they get wet?
and i have no hand controller so how hard is it to make a dash mounted switch to control it?
needs more curry
0272593533
0272593533
Re: warn winch
Try this one....Should find what you are looking for.
http://www.google.co.nz/search?q=warn+w ... iALJ_IyBAQ
Re: warn winch
New from Tigerz11 NZ is a 3pc Wireless Remote kit.
It includes:
1 x 4 pin socket plug( with wiring diagram)
1 x plug in Wireless remote unit
1 x Cable hand controller
I can also do just a hand Cable controller and the a socket plug.
Cheers Brett
It includes:
Cheers Brett
- mud_slinger
Re: warn winch
thanks calvin
do you know if the solenoids will be ok getting wet?
needs more curry
0272593533
0272593533
- hosehustler
Re: warn winch
have a look at mine tomorrow, it's a warn Which i've wired up so no remote required (in cab switch) simple to set up
As for the solenoid box, again have a look tomorrow, I run new cables and mounted solenoids under the bonnet in engine bay, up nice and high, easy to get at and outta the water and crud.
I hate signatures
- mud_slinger
- mud_slinger
Re: warn winch
so wired up winch but we think the solenoid pack is either wired up incorrect or poked. we bypassed solenoids and winch worked.
we went by wiring diagrams on the net but yea still not happening.
can anyone take a pic of their solenoid wiring? or either im thinking of ditching them completely with one of these
http://www.trademe.co.nz/motors/car-parts-accessories/other-accessories/auction-419830824.htm
will this do the job and handle the current?
needs more curry
0272593533
0272593533
- crazyclark31
Re: warn winch
yeh should handle it but i do know the runva 12v comes with a 600amp solinoid.
If you use that solinoid then i'd also be running 50mm2 power cables to help keep the temps down
Re: warn winch
mud_slinger wrote:do you know if the solenoids will be ok getting wet?
I have a XD9000i which has its solenoids on the winch.
Been under water / mud....
Still going strong after 7 years.....
But if you have ones that you can relocate..
Get them up into the engine bay....
Offer them a bit more protection...Wont hurt.
Calvin
Re: warn winch
get a decent solenoid, a cheap one will not hold load
current, if it breaks in the bush you can not fix it
TG are the best from Tigers
- hosehustler
Re: warn winch
I'm picking nothing wrong with solenoids....this may help
If it's a late model winch it will have a five pin plug hand controller (five wires green, black, white, brown, red.
If it's an earlier winch it will have 3 wires for hand controller green, black and white.
In both cases;
Green... winch in
Black.....winch out
White....12v
early hand controllers had 3 pin hand controllers, later 5 pin. The 5-pin is a double-fault grounding system or some such (I think) to aid in preventing the winch from burning itself up in the event of a short. The ti's may also use one of those pins for thermal data.
So simpliest way to get arond the problem is to cut the red and brown wires and join them together or just bridge them where the controller plugs in, then the wiring required for in cab controller is the same as the older 3 wire , pretty sure thats what i've done will double check tonight, give me a call on 0272074454 if you want:wink:
In both cases;
Green... winch in
Black.....winch out
White....12v
I hate signatures
Re: warn winch
I don't know if this will help, but here are some schematics.
- mud_slinger
Re: warn winch
its a 3 wire i think. wen we flick the switch 1 solenoid clicks and the same thing happens wen we flick switch op way. winch doesnt do anything. i would have thought 2 solenoids would switch together
i might give you a holla tim when i get back to chch this weekend
cheers tim
cheers tim
needs more curry
0272593533
0272593533
Re: warn winch
mud_slinger wrote:its a 3 wire i think. wen we flick the switch 1 solenoid clicks and the same thing happens wen we flick switch op way. winch doesnt do anything. i would have thought 2 solenoids would switch together![]()
cheers tim
I just replaced my Warn solenoid pack with something much smaller, so if you need some solenoids let me know....
Who knew Prados could fly?
Re: warn winch
wjw wrote:I just replaced my Warn solenoid pack with something much smaller, so if you need some solenoids let me know....
Did mine a few years ago now, much better, don't need to worry about them going click and not working as they used to (warn ones)
- mud_slinger
Re: warn winch
wjw wrote:mud_slinger wrote:its a 3 wire i think. wen we flick the switch 1 solenoid clicks and the same thing happens wen we flick switch op way. winch doesnt do anything. i would have thought 2 solenoids would switch together![]()
cheers tim
hey bill what ones did you end up using and what costs? the warn pack is huge
needs more curry
0272593533
0272593533
Re: warn winch
Superwinch 12V from Traxion, will probably be around the $280 mark. I ordered them through Rick @ 4wdacc. Glad I did, fits perfectly behind the front indicator
