Long time reader first time poster
For all Suzuki related topics
1600 manual or 2l v6 auto?
1600 manual
0
No votes
2l v6 auto
0
No votes
Total votes: 0
tnr
Post by tnr »
First of thanks for some great reads and inspiration. So i found my self with 2 zukis now a v6 auto escudo with low km and a jx vitara 1600 5 speed. I wanna mod one into a offroad toy tryin to decide what 1 to do, which one would you guy say would be better to mod. My other question is about the 1600 it is leakin/using oil i gave it a good degrease it looks to be coming from the rocker cover gasket got a feeling its not a simple leak though any idea what would be causing this? it doesn't use water or over heat and the water is clean?
Lynx
Re: Long time reader first time poster
Post by Lynx »
Hey and welcome, if its just the rocker cover leaking, then its pretty simple to fix, by just replacing the gasket. Would take like a hour max.
Cheers Daniel
tnr
Post by tnr »
oh yea cool i was just woundering if it was a sign of something else.
Lynx
Post by Lynx »
Id also check you PCV valve and Breather tube, for blockages or obstructions, Its the valve and tube coming off the rocker cover to the air inlet.
Cheers Daniel
tnr
Post by tnr »
will do thanks
badnuz
Post by badnuz »
mod the 1600, easy to do, lots of tips on here, and spare parts are cheaper and more common ( im led to believe...)
QUADRACER
Post by QUADRACER »
the oil leak will be a o ring on the distrubitor housing atthe back of the engine , common fault
o ring for suzuki about $4
tnr
Post by tnr »
QUADRACER wrote:the oil leak will be a o ring on the distrubitor housing atthe back of the engine , common fault
cool thanks i will check that it looks to be coming out the rocker cover and onto the exhorst manifold.
tnr
Post by tnr »
badnuz wrote:mod the 1600, easy to do, lots of tips on here, and spare parts are cheaper and more common ( im led to believe...)
yea thats what i was thinking and i could sell the v6 standard for more
tnr
Post by tnr »
what do you guys think of the spring spacers for a 2 inch lift and another 2 inch body lift running 31" on 8" rims?
Return to “Suzuki”
