96 mitsi challenger
kiwi40
Stropper
96 mitsi challenger
Post by kiwi40 »
hi first time here just brought 96 challenger over weekend have a kind of a shudder from the back end could it be wheel allingment? back shocks worn or something else back end is quite bouncy not sure if this is common any help much appreciated
FORGE1
Re: 96 mitsi challenger
Post by FORGE1 »
kiwi40 wrote:hi first time here just brought 96 challenger over weekend have a kind of a shudder from the back end could it be wheel allingment? back shocks worn or something else back end is quite bouncy not sure if this is common any help much appreciated
My old one (just sold over the weekend) was like that and I put new shocks in before they took it away and made some difference but the standard rear springs are quite soft. In regards to the shudder I had a similar thing in my bighorn as well and I re-greased the rear driveshaft and changed the rear diff oil and mine went away.
hope that helped
waypa
Post by waypa »
I to have a 96 2.8 D and would also be looking at rear U/V joints, possible problems with slippery diff. Find some body who will let you exchange shafts,this will tell quicky and cheeply if problem is in SHAFT OR U/V JOINTS.
kiwi40
Stropper
Post by kiwi40 »
thanks for that, was in garage today the done wheel alignment n balance mad e abig diff already... shocks were shot as were front bushes on sway bar so will get this fixed n c how it goes
Return to “Mitsubishi”
