But after the last WOF fail
Bad bits:-
Noisy mains, clutch going, starter motor squeals like a stuck pig, leaking power steer pump, exhaust leak, drivers front door caught in wind gust and doesn't close properly. Interior average/sad
Good bits:- its a zook
5 x Maxxis buckshot mudders, good tread, ok overall condition.
About 275k on the clock. I took part in the Zuki Central Challenge at Easter and was placed 1st in class for the Jimmny Khana. Has Monroe Adventure 4X4 shocks all round, STD zook springs.I have a 50mm body lift kit also to go with it, didnt get to fitting it before the failed WOF.
Im in Upper Hutt if you wanna veiw. Will be taking a few things off like the PRS and air horns for the Hilux.
Cheers Paul.
