ok so my gearbox is about to crap out in my td27 terrano. does anyone know of a stronger gearbox that i could put in. or any way i can make mine more heavy duty?
any help will be great. cheers
td27t gearbox
Re: td27t gearbox
just buy a safari or isuzu.
Re: td27t gearbox
dont tow in 5th gear and put in a heavy duty bearing kit. or buy another truck. this will always be a problem for td27s
another d21 terrano
ex lancer build
ex lancer build
Re: td27t gearbox
Get it rebuilt now, before it goes bang. Much easier and cheaper to do...
Get a decent bearing kit (not a cheapie) and it'l be strong as.
I tow heavy loads in 5th, and give mine heaps and its great.
Just be reasonable, dont clutch dump, or load it up heaps in 5th etc
- mud_slinger
Re: td27t gearbox
also the filler bung is in the wrong place,its a factory fault it sits too low thats why they wear bearings. pull out gear lever and pour down the hole.
needs more curry
0272593533
0272593533
- workin on it
- Driver/Navigator
Re: td27t gearbox
thanks for all your input ill go with the good berings and see how that turns out
