14th 15th jan
14th 15th jan
did a trip up thompsons track ,slip stopped play :D
sibainmud
Re: 14th 15th jan
Post by sibainmud »
Took a new front diff for a test drive. Went well.
Nothing to report :P
Edit; P.S Coxsy, hope ya drove around the road and went up the other side :lol:
Long way to go to find that :(
Nizsafari
Re: 14th 15th jan
Post by Nizsafari »
Waited for my new winch to arrive..... still waiting....
Drurban
Re: 14th 15th jan
Post by Drurban »
Hi All,
A bit more progress on the box for the back of my truck about 90% finished, just have to do the top and install my Air-Zenith compressor, and wiring and then the back is all done. Here are some photos.
Big Thanks goes out to Hilux Dan for the Idea of making the frame out of steel and the fixing of the compressor, als a BIG thanks goes out to madlux for giving his time, skill's and the use of his tools for making it happen.
sibainmud
Re: 14th 15th jan
Post by sibainmud »
Drurban wrote:Hi All,
Is that "The Richard" I see there? :lol: :lol:
Looking good.
Drurban
Re: 14th 15th jan
Post by Drurban »
Yep well spotted there Simon, thought it would be good for a laugh :lol: :lol: :lol:
FORGE1
Re: 14th 15th jan
Post by FORGE1 »
Pulled the motor out of the parts bighorn this arvo. decided to start at 3pm had it out by 5.30. Also got the trans ready to drop out tomorrow morning (exhaust in the way) hense the motor coming out first so I dont have to cut the exhaust to get the trans out.
Updated 15/01/11 - Got the front diff out, trans out, control arms out
Plan for the next few days is to get all the steering out and, torsions and a few other bits out. Maybe the rear diff if I get time.
Re: 14th 15th jan
well that sucks safari has flat batteries :evil:
kbushnz
Re: 14th 15th jan
Post by kbushnz »
Spent a couple or three hours in Woodhill on Saturday.
New pump works well. Plenty of go now.
Can cruise around in H4 now. As before as soon as it loaded up the EGT just climbed and climbed to silly temps.
Now they are considerably less....
Pump still a little advanced, get a tinkling sound during hard acceleration....
Spent the morning today giving her a bit of a clean, enough so I can work on her without getting all sandy/dirty :lol:
SP450andLE
Re: 14th 15th jan
Post by SP450andLE »
In between working on my Mini, I have started looking at doing a LHS high-mount alty swap on the Lada. Maybe even a high out-put one too...
Should be fairly simple if I keep the standard alty though.
It'll be so much easier to get to the alty then, and it'll be up and out of the mud too - the way it should have been in the first place! :roll: :lol:
howieh
Re: 14th 15th jan
Post by howieh »
Stripped the red grease, from my new Ridge Ryder 9500 from super cheap,and replaced with marine grease.
Found a bit of ply wood to replace rear door card on discovery to fit a cooking shelf.
nurse
Re: 14th 15th jan
Post by nurse »
Went to CZ Trial's and broke another truck,
Will upload video when I figure out how to
Re: 14th 15th jan
nurse wrote:Went to CZ Trial's and broke another truck,
yeah and thats not all you did :x :roll:
mudmike
Re: 14th 15th jan
Post by mudmike »
well friday, wired in an idiot light on my pto( Hope it will stop me from driving off with it still engaged ). Then put on the muds. Drove up Thompsons to look at the slip on Saturday with the club. Bugger that shortened that trip a whole lot.
Took the muds back off then work on sunday.
kbushnz
Re: 14th 15th jan
Post by kbushnz »
mudmike wrote: wired in an idiot light on my pto( Hope it will stop me from driving off with it still engaged )
Funny you should say that, its one of my next mods...
I am putting a switch in one of the bung holes for that shaft which engages / disengages. Is that how you did yours.??
phraza
Re: 14th 15th jan
Post by phraza »
SP450andLE wrote:and it'll be up and out of the mud too
will it ever see mud anytime soon? :D
Not much for me this weekend, went for a 6 hour tramp in the waitakeres, pretty damn muddy in there!
2WD 06 Hilux... for now
Re: 14th 15th jan
mudmike wrote:well friday, wired in an idiot light on my pto( Hope it will stop me from driving off with it still engaged ).
yeah its not healthy for the bullbar when you do that, I dont usually have a problem forgetting to disengage the pto but I've got a forward/reverse pto thats using a T Bar lever instead of a toyota lever and the way the linkage is setup theres only about 10-15mm back and forward movement in the lever and it farking hard to find neutral in the middle :x
Re: 14th 15th jan
oh been there done that, real bastard isn't it, got idiot sign saying [pto in neutal] on the dash :roll:
SP450andLE
Re: 14th 15th jan
Gah, idk. I'm trying, as much as my spare time and funds allow - and I seem to have a distinct lack of both of those! :roll:
stinky
House Hubby
Re: 14th 15th jan
Post by stinky »
That shit will buff right out dude no worrys
____________________________
Martin
http://www.wtbs.co.nz
T-Boon
Re: 14th 15th jan
Post by T-Boon »
V8 and box is mounted :D :D :D
gonna have to shorten rear and lengthen front driveshaft, but aircon is worth it.
Gotta pull it out again tomorrow to weld up all the mounts, and then its wiring time !
Then spent today at Hampton downs testing in a mates drift car
and I was driving the D1 FC.
And chatted up a hot (sofukinghot) German tourist, sorted her a ride in a drift car and she`s keen to go see a movie next weekend !
Today was a good day !
To Boon or not to Boon.
dtchch
Re: 14th 15th jan
Post by dtchch »
Bugger all done on the truck this weekend, though a lot to do this week!
Pull off intake manifold (bastard, really wanted to avoid that :lol: )
Take head in to be checked and milled, new head bolts and perhaps valves looked at.
Try to remove this bloody crank pulley with some heat
To buy:
Head gasket, thermostat gasket, cam seal, crank seal, dissy cap/rotor
Crank pulley, key, Crank bolt
Waterpump + seal
Timing belt cover & seal
Intake manifold gasket
Heater send hose, lower radiator hose
rangimotors
Re: 14th 15th jan
Post by rangimotors »
T-Boon wrote:And chatted up a hot (sofukinghot) German tourist, sorted her a ride in a drift car and she`s keen to go see a movie next weekend !
pics or it never happened :lol:
andy3542
Re: 14th 15th jan
Post by andy3542 »
went up to woodhill for the first time in a year (as a driver) truck went amazing. :D drove places that i couldn't/wouldnt have thought of doing when it was an auto! slight problem with cooling but that should be an easyish fix
also watched a 'rated' tow hook get straightened out causing the snatch strap to fly off and take out a spot lamp and my grill... :?
landy flex
http://i1219.photobucket.com/albums/dd433/andy3542/Land%20Rover/Image9.jpg
http://i1219.photobucket.com/albums/dd433/andy3542/Land%20Rover/Image7.jpg
a little muddy
http://i1219.photobucket.com/albums/dd433/andy3542/Land%20Rover/Image6.jpg
tried resizing them all the way down but still not working!! :x
Offroad Addiction TV
Drurban
Re: 14th 15th jan
Post by Drurban »
Nice one Andy but your trucks still looks the same :roll: nah just kidding mate, look forward to meeting you at the next outing.
mudmike
Re: 14th 15th jan
Post by mudmike »
Mine is a two direction pto, so used a magnetic switch so off in closed and light goes if moved even a small amount. works well so far.
crazyclark31
Re: 14th 15th jan
Post by crazyclark31 »
thats what they sposed to do so there not a hunk of metal flying thru the air
Re: 14th 15th jan
maybe winching them would of been safer
Re: 14th 15th jan
Madaz
Re: 14th 15th jan
Post by Madaz »
Looks like your navi needs to eat some more pies :lol: :lol:
