hi all can anyone inlightin me on changing out a 24volt auto to to 12volt inturnals. I have heard that it can be dune with terrano solidnoids.
Also what are the clutch packs in the auto similer to i need the outo to handle 300-400kw
thanks mike
converting a 24v gq saf auto to 12v
Re: converting a 24v gq saf auto to 12v
IF i remember rightly the Nissan skyline GTS4 auto trans shares the same internals as the patrol just with a different transfer case bolted to it.
and the GTR gearbox also shares components with the patrol too.
- crazyclark31
Most people use the v8 intera
ls from the vh45.think from memory the handle upto 500hp
vh 45 internals swap over clutch packs the lot
been there done it ,
its easy ,with big HP remove overdrive out of torque converter and i would go manual valve body if i did another one
would be worth sending to nelson get it done by guys who have done a few of them
GO HARD OR GO HOME !
2015 JK Rubicon
2015 JK Rubicon
