does anyone know if the petrol fuel senders on the top of the tank will work with my diesel tank?
i just got one cheap and didnt want to have to drop the back of the tank down and remove etc and find out it isnt interchangable.
mine keeps reading quite low, and sometimes it goes higher for a couple of mins and drops again. ive checked connections etc.
any help would be apprieciated.
cheers.
fuel level sender for petrol or diesel ln61 hilux
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
Re: fuel level sender for petrol or diesel ln61 hilux
Roenut wrote:does anyone know if the petrol fuel senders on the top of the tank will work with my diesel tank?
cheers.
I'm no sparky. Just installed a new one. Don't think it would matter petrol or diesal.
ford ranger wildtract and sj.
was it a brand new one? costly?
Roenut wrote:was it a brand new one? costly?
Cheap as, around $55 bucks. I brought this one on trademe from little red auto parts. Easy to install to. Used the exiting gage screws and hole in my Zuki tank.
There are dearer one's but it does the job. It leaked the first time I installed it. so I re installed the sender using gasket silicon and it is sweet as now.
Listing #: 440701412
pretty sure I have a diesel one in a spare tank in my shed if you get stuck
just put a petrol one in, 10 times better condition then the origional one.
will have to see if it actually works when i fill her up tommorrow.
i dont think i want to change another onein a little while. ...them tanks are heavy when your using your knee and hand to hold it up!!!!!!r
Is this in a hilux or a surf? In a Surf isn't there an inspection plate under the back seats that givers you access to the fuel sender in the top of the tank?
Smurf wrote:Is this in a hilux or a surf? In a Surf isn't there an inspection plate under the back seats that givers you access to the fuel sender in the top of the tank?
nope, mines a surf, under the inspection plate under the seat theres the outlet and breathers etc.
i had to completely unbolt the tank and drop it down to get a stubby philips on the other end of the tank. it was roughly positioned where the body curves up to form the boot tray
