you cant be flippin serious
- Driver/Navigator
so i JUST brought a 86 landcruiser with a pto winch and some other goodies. i just drove it down to dunedin. and everything was fine i was driving it today and it seems it grinds when i put it into 3rd from second unless i do it REALLY slow or double clutch it. then it goes in fine it usually goes into 3rd from 4th fine but sometimes grinds.
i am absolutly pissed off about this ive had it up to my eye balls with problem lately. can you guys please explain what it could be. if anybody know any info would be great ae cheers gbh
- muddyhilux
Re: you cant be flippin serious
id start by just double checking there's the correct amount of oil in the gearbox and that it looks to be of good condition,but if all that's ok it sounds like the gears syncos are going.if they have syncros that is. I'm not sure if they do
have you checked the gbox has oil?, may be worth doing an oil change
its a 26 year old truck with half a million click's on the clock the syncros will be a bit worn, you'll get used to the gear changes
- Driver/Navigator
Sadam_Husain wrote:its a 26 year old truck with half a million click's on the clock the syncros will be a bit worn, you'll get used to the gear changes
it has only got 167 thousand ks on it
so long as the bearings arent noisey and its not jumping out of gear it'll go for ever, you'll soon get used to changing gear at the right speed and revs so it dosent grunch as much between gear changes, did you test drive the truck before you brought it
- Driver/Navigator
yes of course it just seems to have come up in the last couple of days.Sadam_Husain wrote:so long as the bearings arent noisey and its not jumping out of gear it'll go for ever, you'll soon get used to changing gear at the right speed and revs so it dosent grunch as much between gear changes, did you test drive the truck before you brought it
- rangimotors
goosebayhunter wrote:Sadam_Husain wrote:its a 26 year old truck with half a million click's on the clock the syncros will be a bit worn, you'll get used to the gear changes
167 on the clock but how many on the truck who knows.
rangimotors wrote:goosebayhunter wrote:Sadam_Husain wrote:its a 26 year old truck with half a million click's on the clock the syncros will be a bit worn, you'll get used to the gear changes
Good point.
Mine is only 7 years younger with 212,000k's on the clock, but the syncro from 2nd to 3rd is a little dodgy so I just move it slower.
goosebayhunter wrote:yes of course it just seems to have come up in the last couple of days.
Gearboxes do that when they are full of Banana skins too
I always changed oil and threw some Moreys oil stabilizer stuff in with it. Seemed to help the navara G/boxs last longer and change nicer.
If they have the nylon grommet on the gear lever these can cause problems when worn and are an easy fix.Makes gears hard to change and sometimes simply wont go in.Remove your gearstick from the top of the box and have a look. If the grommet is worn fit a new one they are cheap. flag.
- Winch master
Also just got an 88 BJ70 with the same problem. Only 140k's on mine. Test drove fine, but started grinding a bit into 2nd. Did an oil change, only to find the gearbox oil was low. It had all gone into the transfer case! Common problem from what I've read online? Anyway.... In getting the gearbox to transfer case seal replaced at the moment.
Might be worth looking at?
Oh and Hi! Great forum!
- zephyrheaven
An old but still relevant trick from the 80's in Toyo's (and loads of others) is to buy some Slick 50 http://www.finda.co.nz/business/listing ... 50-nz-ltd/
I dont condone many additives as a rule - but this thing is wonderful in manual tran's that are a little lazy in syncro's & you dont wanna fix it yet.......
http://www.trademe.co.nz/motors/car-par ... 452948.htm
