Does anyone know if 80 series front diffs can turn a tighter steering lock, than say a 70 series or a hilux diff?
And if so how do they compare to a gu nissan diff?
80 series diffs verses GU diffs
Re: 80 series diffs
Madaz wrote:Does anyone know if 80 series front diffs can turn a tighter steering lock, than say a 70 series or a hilux diff?
they have a better lock than hilux and 70 series. As for gu don't know .
Pedro
Re: 80 series diffs
Cheers for that, standard toyota aisin freewheeling hubs fit them as well?
Is that correct??
Is that correct??
Re: 80 series diffs
Yep, well the early 80 series. The later ones have a longer outer spline on the CV. I use early 80 series drive flanges on the lux axles in my zuk. You could use them on the later ones, they would just need a 5mm (I think) spacer
Re: 80 series diffs
Madaz wrote:Cheers for that, standard toyota aisin freewheeling hubs fit them as well?
Is that correct??
Pre 94, ... dont want them damn spacers
After 94 is when they changed to allow for ABS...
Who knew Prados could fly?
Re: 80 series diffs verses GU diffs
Yes agree don't like the idea of spacers between the hub and FWH, more likely to shear off the studs.
Could just trim the end off the CV and cut a new circlip groove.
Tim
Tim
If it's jus the cv that's different why not just run early cvs in the later housing? (assuming you ended up with a later housing that is)
Didn't barbie drive a jeep??
