KZN185 Surf Lift kits
Hi all, I have a 98 intercooled surf. When I had my earlier model 130 I picked up a great Raw Nitro kit on Trademe, had shocks, springs and brake extender hose.Does anyone know where these are available for the 185. Was around 2 inch lift and handled great on and off road and was a reasonable price
Any other suggestions welcomed
Re: KZN185 Surf Lift kits
where are you situated?
Sam
Sam
Manawatu
Are you doing work yourself? Not sure but I'd say you have the shop Autolign up there.. We do down in Chch I've delt with them on Raw Nitro stuff, helpful and well priced.
even if they don't give Tim a call at autolign on wordsworth street. He will be able to sort you out.
Sam
Sam
Thanks, I have a price from autolign seems quite reasonable
how did this turn out for you, Wattsy?
Have had the Raw in for a fair while now. This kit is for the prado as well. I fitted 15mm coil spaces on front as well to get 50mm lift all round. Handles well
hey where did you get the front spacers from mine sits a tad low in the front?
Autolign I got the shocks and springs from them as well. Keeps it sitting even. Dont think they cost much from memory. I must say I added a 3inch exhaust and dump pipe and that has made a significant difference to performance as well.
Hi guys
I'm a new member and have a Surf 185 V6 and am looking to lift 50mm to assist in towing the boat and keeping my truck out of the sea as much as possible. I have been discussing Raw Nitro shocks with BNT and trying to agree on the spring options. Given I want to use primarily on road the ride and handling are important to me as well as being able to tow 1500KG boat could you advise what you've used thanks
PS I will provide a little bit more of a profile this evening
I cant remeber to be honest is there standard 50mm spring and suspension lift. Front only does about 35mm hence the spacers. These are the same as the Prado as the 185 surf has the same chassis. I think the Prado is slightly heavier although I find mine ok and I only really do shiny school fundraiser trips and I have mud tyres on as well
what tire size are you running, Wattsy?
16x8 White spoke rims Kumho R265/75/ SR16 Road Venture MT R265/75/ SR16
Well after a chat with Iain at Racelign have decided on Bilstens all round and Dobi springs on the back, should get about 20 to 30 mm front lift and 40 to 50 mm on the back, not sure exactly how much as I don't know how much the old springs have sagged.
Booked in next week
so will let you know how it all works out, looking forward to some better handling and less sag when I tow
Booked in next week
- floatingkiwi
EFS is another option, I have found them fairly good even when unloaded, but for some reason my truck must be heavy in the front as I had to go to the XXXHD spring in the front to get the lift I wanted (about 2.5 in)
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
