Nissan Mistral blowing black smoke
Noddy
Stropper
Post by Noddy »
Hi my Nissan mistral blows black smoke under heavy acceleration but OK under normal load Think this is normal for this type of motor but need to hear from other owners if this happens to them Cheers Noddy :) :)
uptomynutsinruts
Re: Nissan Mistral blowing black smoke
Post by uptomynutsinruts »
Try throwing a bottle of injector flush through it, that should help a little bit, the only other thing I can think of to do is to block the EGR off
DaveM
Post by DaveM »
How much smoke? Hard to tell if its normal without knowing if it's excessive or just a little.
tweake
Post by tweake »
Noddy wrote:Hi my Nissan mistral blows black smoke under heavy acceleration but OK under normal load
(i assume you mean TD27 engine?)
i would not conceder it normal. i very rarely see diesels blowing smoke these days out on the road.
it could be egr being stuck open. if it is then it would have less power.
more than likely its probably needs injectors to be reco'd.
Fusion235
Post by Fusion235 »
My Terrano did same thing, same motor, had the injectors cleaned out & reconditioned by a diesel specialist , ran clean as a whistle after that.
