1HDT Engine Drain Size & thread & Holes in Shock Towers
wjw
Post by wjw »
hi Guys,
Anyone know what size and thread the 1-HDT coolant drain is?
Also what are the rules about bolting things to shock towers? need to make 3 10mm holes :-)
Thanks,
Bill
Who knew Prados could fly?
We are Borg
Re: 1HDT Engine Drain Size & thread & Holes in Shock Towers
Post by We are Borg »
I can measure the drain cock in My cruiser tomorrow if it is the same as the ones on an 1hz :)
wjw
Post by wjw »
We are Borg wrote:I can measure the drain cock in My cruiser tomorrow if it is the same as the ones on an 1hz :)
That would be grand. Thanks. And yes it should be the same.
snotgoblin
Post by snotgoblin »
given the rules around corrosion within 200mm of shock mounts, I am picking that drilling is a no no depending on where?
what are you mounting?
wjw
Post by wjw »
snotgoblin wrote:given the rules around corrosion within 200mm of shock mounts, I am picking that drilling is a no no depending on where?
Engine coolant heater, has to be down low and in the US they mount them to the shock mount on 80's. Can't find space anywhere else :-(
We are Borg
OHhh I wants one of these :) how does it fit/work the only ones i have seen replace a frost plug .
wjw
Post by wjw »
This is what I bought:
http://www.ebay.com/itm/180781494314?it ... 1609wt_689
It's gravity fed and uses convection so the inlet hose at the bottom needs to be lower than the engine drain.
We are Borg
looks great :)
Sorry never got under the bonnet of my truck today,got waylaid by a Gearbox being a S**t :(
wjw
Post by wjw »
Hey dude, did you have chance to look? ta
We are Borg
Just had a quick look and by my eyeballometre i would say that it is 10mmx1.25 ( or 10mm metric fine)
wjw
Post by wjw »
We are Borg wrote:Just had a quick look and by my eyeballometre i would say that it is 10mmx1.25 ( or 10mm metric fine)
Great thanks, the part that came with the heater won't work :-)
We are Borg
yeah I would guess that as it came out of the states it would be 1/4 or3/8 NPT fittings, as it is only a hose fitting that goes on there I would just retap the oil cooler cover to suit ( they are cheapish and easy to do if/when you sell vehicle)
Return to “Tool Shed”
