Won't turn off
For all Suzuki related topics
dean zuk
Won't turn off
Post by dean zuk »
So i've just finished wiring up the g16a tbi into my 413, it started and ran after a couple of goes :D but now it wont turn off when you turn off the key, i had to pull the battery cable off to stop it :oops: .
Any ideas what would cause this? I assume ive hooked up something wrong but have no idea what as it goes lol
Thanks for any ideas
Dean
sibainmud
Re: Won't turn off
Post by sibainmud »
Check alternator wiring, could be getting a back feed from the warning light circuit.
Re: Won't turn off
yep x2 I've only had that problem when swapping around alternators :x
dean zuk
Re: Won't turn off
Post by dean zuk »
Cheers guys will have a look at that tomorrow
Ben
Re: Won't turn off
Post by Ben »
I'd say you wired the "ignition on" signal for the ecu to permanent power as a first guess.
Shouldn't be the alternator as you should still be using the 413 loom for the charging circuit.
Ben
dean zuk
Re: Won't turn off
Post by dean zuk »
Ben wrote:I'd say you wired the "ignition on" signal for the ecu to permanent power as a first guess.
And we have a winner :oops:
Whereabouts should it go? Coil fuse?
Dean
kernels
Re: Won't turn off
Post by kernels »
At first guess I would say that you would wire it to a signal from the physical ignition switch that gives you 12V when the ignition is in the on/run position. That way when you turn the ignition off you take away the 12V and the ecu kills the power that feeds the spark (ignition) system.
Ben
Re: Won't turn off
Post by Ben »
As per Kernels suggestion, It should go to the "ignition on" wire at the ignition key. From memory I think it is black with a blue trace, but make sure you check. There should be 12V there when the key is in the "on" position and the in the start position and 0V when the key is an acc or off position. You can check that without starting the engine by disconnecting the starter solenoid wire and turning the key while checking the voltage with a multimeter.
Ben
dean zuk
Re: Won't turn off
Post by dean zuk »
thanks guys that makes alot more sense than what i had done :oops:
Will move that wire and see how i get on
Return to “Suzuki”
