How much boost would u run in a 3l
in4rhvn
Post by in4rhvn »
was wondering what is the max you could run in a 3l 2.8 turbo diesel surf and what is standard boost
tweake
Re: How much boost would u run in a 3l
Post by tweake »
there is no standard boost, they are not factory turbo'ed.
with out intercooler generally 12psi if your using the 2.4 turbo. with good intercooling as much as you like. a few people around running 30psi pr more.
its the fueling that kills them.
in4rhvn
Post by in4rhvn »
r u serioes 30 psi so mine doesnt make any boost atm and i would like to put it on ten pound
crazyclark31
Post by crazyclark31 »
yep.With out pump mods you'd would only really wanna go around the 15 -20psi. But as tweake said anything in double figure psi you want to run a decent intercooler to get the best outa it and to make motor stay reliable.
Remember when uping the fuel you don't want smoke when on boost.
KIWI_TERRANO
Post by KIWI_TERRANO »
Chuck a boost gauge on it see what its makIng now im guessing 8ish, with out intercooler i wouldnt go above 10 with a decent intercooler i wouldnt go above 12-13 psi anymore an your looking at broken cranks blowing ring etc, factory. Pump with adjusting fuel will handle that to
in4rhvn
Post by in4rhvn »
cheers for the info everyone but i will be going 11 pound max i recon and i thought it doesnt run any boost thats what the first comment said :?
