first off i removed the ac radiator to make room for the intercooler as i didnt want to cut any holes in the body work for the piping and this was the only possible place i could see for it ( good excuse to turn the ac into onboard air wich so far works amazingly surprised how fast it fills the 20l tank much faster then any 2.5hp household compressor) any way once i had the intercooler mounted it was time to plumb it up unforntunaty this was the most expensive part of the project that i had not thought of when considering the intercooler. all the plumbing was prety straid forward i cut the intake hose from the tubo and hose clamped strait onto the oval intake tube (hope this joiner stays on and doesnt leak..) only other issue was the tight passage between the battery box but with a little trimming and modification to the battery clamp was a perfect fit.
pipes are 2" from tubo to intercooler and 2.5 from intercooler to the intake.
intercooler cost $100 dollars and pipe and fittings were another $150 alot cheaper then the 90 series $800 second had alternative (but at the cost of the ac witch i am starting to miss
have taken vehicle for a small drive down the road but will get back with results after a proper drive
parts:
intercooler and alloy to mount
*2.5" 180 alloy bend
*2.5" 90 alloy bend
*2.5" alloy strait
*3"-2" silicone reducer
*2" 90 silicone bend
*2" strait alloy tube
*3"-2.5" 90 silicone bend
*3x 2.5" silicone joiners
*2.5-2.75 silicone reducer (for the inlet)
*intercooler hose from a mitsubishi delica (braided hose with bends to get around the steering perfect fit)
*HOSE CLAMPS lots of them!
think thats everything
