WTB Old Man Emu Shackles and Pins
Selling or wanted vehicles.
snotgoblin
Post by snotgoblin »
I am after some front shackles and pins for my 1980 BJ40 Cruiser.
I have the springs and shocks.
MNC
Re: WTB Old Man Emu Shackles and Pins
Post by MNC »
snotgoblin wrote:I am after some front shackles and pins for my 1980 BJ40 Cruiser.
Why not just replace the bushes in the OME springs you have to suit the smaller diameter pins you already have?
Otherwise:
http://www.4wdbits.co.nz/ProductsList.aspx?CategoryID=34
try badnuz
snotgoblin
I have not been able to find any bushes that will fit the spring eye and has a 15mm ID.
So - I guess I am after a shackle set up with the two different pin diameters...
Forgot about 4wdbits.. cheers for the link..
Those prices are way cheaper than the new OME quotes I got..
MNC
Post by MNC »
snotgoblin wrote:I have not been able to find any bushes that will fit the spring eye and has a 15mm ID.
Try this link:
http://www.4wdbits.co.nz/ProductDetails.aspx?productID=476
snotgoblin wrote:So - I guess I am after a shackle set up with the two different pin diameters...
I've been though this a couple of times before and I reckon changing the spring bushes are you best bet.
If you go with the bigger fixed pins they wont fit your factory pin mounts (different sizes).
