terrano torsions
Ryan
terrano torsions
Post by Ryan »
i have put 2inch lift springs in the back of my 94 terrano and have had the torsions wound up at the front and wheel aligned, I am looking at putting an ARB copy steel bull bar on and the front will sag.. just wondering how much winding can be done on torsions??
albundy
Rolly Polly
Post by albundy »
Put your truck up on stands take the torsion bars out and twist them a couple of notches. This is called reindexing. Sad thing is you will probably have to get it all aligned after that. I did this and worked a treat.
Ryan
Post by Ryan »
albundy wrote:Put your truck up on stands take the torsion bars out and twist them a couple of notches. This is called reindexing. Sad thing is you will probably have to get it all aligned after that. I did this and worked a treat.
cheers al
now i may have found an alloy bar so may not need to mess
with torsions after all....yahoo....
