has anyone done it ,have searchd through pages on here,
i have got a complete td27 fuel pump,have read somewhere before that its possible to do this to a td42 think read it on outerlimits but the website down this morning,
my safari was non turbo
i run a ct26 with custom manifold and intercooler
also in the progress in making a bigger inlet manifold for the old tart
any help wiv the fuel pump would be great
thanks vince
td27 boost compensator on td42
Re: td27 boost coompensator on td42
yes did it to mine so did dieselboy photos on both build pages
- crazyclark31
ihmo with the ct26 i'd doubt you'd need the comp as the turbo is on the small side and without altering the fuel and at 10-15psi it'll be running around its peak efficentcy. Had one on my shorty and when i wound the fuel up,even with it pushing 18psi, it smoked on full boost. Changed to a td05 and without changing the fuel(from the smokey ct26 setting) the difference was night and day.
The boost comp is need then
And yep they do fit pretty easliy so i'm told.
crazyclark31 wrote:ihmo with the ct26 i'd doubt you'd need the comp as the turbo is on the small side and without altering the fuel and at 10-15psi it'll be running around its peak efficentcy. Had one on my shorty and when i wound the fuel up,even with it pushing 18psi, it smoked on full boost. Changed to a td05 and without changing the fuel(from the smokey ct26 setting) the difference was night and day.![]()
The boost comp is need then.
ct26 small size?? , they aint a small turbo
which one did you have ???
mine isnt a diesel ct26,ie 80 series cruiser, mine is the supra/celica twin outlet/inlet etc with mods done to it,smaller compresser wheel which is steel now rather that ceramic.mine dont smoke on full boost which if i blank off wastgate i get 22boost,my exhaust is straight through 3inch and exhaust stops just behind passenger seat out to the side aint long at all
coxsy wrote:yes did it to mine so did dieselboy photos on both build pages
read all through pages again like i did when u was doing turbo conversion,you sent it off to do pump mods, kinda want to knw is it hard to do
thanks anyway vince
Re: td27 boost compensator on td42
for my pump gy it was quite easy for him the throttle shaft gave him some trouble i think but worked it out
sorry lost track who was watch what
coxsy wrote:for my pump gy it was quite easy for him the throttle shaft gave him some trouble i think but worked it out
thanks coxsy
bump
anybody shed some light
vince
vince
- crazyclark31
PigFmr wrote:crazyclark31 wrote:ihmo with the ct26 i'd doubt you'd need the comp as the turbo is on the small side and without altering the fuel and at 10-15psi it'll be running around its peak efficentcy. Had one on my shorty and when i wound the fuel up,even with it pushing 18psi, it smoked on full boost. Changed to a td05 and without changing the fuel(from the smokey ct26 setting) the difference was night and day.![]()
they may be a big turbo but they don't flow that much air. By size i was refering to air flow not physical size.even with compressor mods they only flow the same as a tdo4e. Still make the truck bogey tho.
I had one off a 7mgte. Even with the twin outlet ones unless you've got a really good intercooler they turn into an air heater over 18psi. my air temps were around the 150-180degc mark at 17psi. Tdo5 was 90-110 at 14psi.
Anyhow back to the topic. afaik the td27s and td42s are pretty much the same motor and pump execpt for the extra cylinder obviously so can't imagine it would be to hard to put a comp on top of the pump. Just depends on how good you are with the spanners. Best bet would to be to ring a pump place and talk to them.
