$6100 o.n.o
021 397 974
Body/ chassis:
Custom Roll cage tube frame
Mixture of steel and Perspex panelling.
Perspex front and rear screens
Tow hooks front and rear
Fuel tank and radiator mounted in rear
Engine:
289 Windsor V8 engine
New Plugs, Leads, Starter Solenoid, Electronic Distributor, Fuel pressure regulator, and air filter.
Tyres:
5x Simex Jungle trekkers. 34inch by 10.5 by 15. Including spare!! Approx 15-18mm tread
Drivetrain:
40 Series landcruiser gearbox, 4 speed manual
40 Series locked rear diff
70 series (or similar) front diff
Manual locking front hubs
Brakes etc:
Disc brakes all round with individual fiddle brakes on the front wheels.
All new front brake piping
New brake master cylinder, new master and slave cylinder for clutch
Hydraulic hand brake
New hydraulic power steering lines
Suspension:
4 link rear, 3 link with panhard rod in front
Wiring etc:
New Battery
All new wiring with relays and fuses in waterproof box
Switch for radiator fan and battery isolator
Setup for front and rear lights and horn
Interior:
Padded bucket seats with barely used 4 point harnesses
Momo steering wheel, water temperature gauge
Tilting steering column from a 70 series landcruiser
Cupholders!!!
Unfortunately selling due to business needing a cash injection
Custom v8 4wd $6100 o.n.o !!!!
badassblake
- Winch master
- mudlva
Re: Custom v8 4wd $6100 o.n.o !!!!
kricky mate you're dreaming
its the Ford bit that gonna cause all your issues.
