Help with more articulation on r/r
brakes-shocks-lockers-etc
Batfastard
Dr. Love Glove
Post by Batfastard »
I have a 74 rangerove chassis based project.look for some advice on getting more articulation.
Fakey
Re: Help with more articulation on r/r
Post by Fakey »
Little more Info an some pics would help what model range rover, what else you've done to it, is it a buggy? :roll:
Didn't barbie drive a jeep??
Batfastard
Dr. Love Glove
Its a rangie74 two door chassis,s3 landrover truck cab will have a full exo that works into a tube frame rear tray.will bob rear chassis in line with the rear wheels.its set up with the 4spd rr man box, but may go the auto way.will use a 3.9rover worked v8 .will use the rr f&r diffs to begin with to keep build costs to the budget ive set.so i can get out into the mud sooner rather than later,then modify from there.
As we all have to start some where.so was not looking for advice on what would be best but more like what can get me going.cheers
Fakey
Post by Fakey »
Well if all you want to do is get going just run with the rr suspension
Smurf
Post by Smurf »
Fakey wrote:Well if all you want to do is get going just run with the rr suspension
Yep, they flex pretty well in factory form.
ice4x4
Post by ice4x4 »
If you are on a budget. Easiest way to improve the articulation is by dropping the shock mounts by 2". This will give you a further 2" down travel.
But trade off is the shock will now reach its upper travel limit before the axle tube hits the bump stop so you'll need to extend your bump stops thus losing some upwards travel.
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
Batfastard
Dr. Love Glove
ice4x4 wrote:If you are on a budget. Easiest way to improve the articulation is by dropping the shock mounts by 2". This will give you a further 2" down travel.
Cheers for that.
Its strange how most people confuse the word budget with not wanting to spend any money
So if i used some 2or 3"longer shocks would that give me the extra down travel but not effect my up travel
Bulletproof
Post by Bulletproof »
In real life, extra travel down doesn't make a truck that much more capable because there is very little if any pressure on the tyre from the spring with a standard setup.
Cheers Richard
Never say die, up man and try
mazdamike
Post by mazdamike »
dislocation cones and longer shocks
