Knocking noise front right suspension KZN-130
Hey team, I have a 93 KZN-130 and I took her out and shes taken a beating to the front right wheel, either the ball joint or diff?? and now theres a heavy knocking noise and it feels like im going over a speed bump, but its only when im in 4WD it seems to be worst.
Any help appreciated, and im going to apologize in advance because im new to 4WDing. cheers!
Re: Knocking noise front right suspension KZN-130
CV joint broken comes to mind...
got no CV mate
_MUNTER_ wrote:got no CV mate
Have you removed them already?
sounds like the CVs fallen out then
lol Sadam, Could be the double cardon ? found this
http://www.toyodiy.com/parts/p_J_1995_TOYOTA_HILUX_KZN130W-GJMQT_3701.html
oops my bad, yeah CV will need to be looked at
I was thinking more like this..
http://www.toyodiy.com/parts/p_J_1993_T ... _4302.html
Ahhh he found them
Ahhh he found them
yeah i'll take her apart and have look see.
another place to look is the shock mounts.. I threw a rubber out of one once... sounded like I had run over a dwarf with a hammer....
is that the bushers? they should be swt i had those replaced coz i had none haha
_MUNTER_ wrote:is that the bushers? they should be swt i had those replaced coz i had none haha
Yup top and bottom....
yeah should be the CV coz its only in 4WD it happens
Also the double cardon is on the front driveshaft so will only make noises when in 4wd as the pain comes on.. currently thinking i have this problem..
yeah thats the one big
the other thing to check that can cause knocking is in the hub itself there is bronze bushes that become egg shaped. mine started knocking in 4wd only as there was load but after a while they really wore out and it happened when 4wd wasn't engaged so i replaced them, put free wheeling hubs on and they haven't worn out yet.
Sam
Sam
