Another rocklobster question!
For all Suzuki related topics
Supa_zuka
Stropper
Post by Supa_zuka »
Hey guys,
Looking into doing a rocklobster on my 413 thrasher. I'm located in Kaikoura but was wondering where the best place is in Christchurch or elsewhere to get the gears machined. Going to try babylobster it first to see if that will spin the 31's abit better.
Thanks,
Tim.
pressy
Re: Another rocklobster question!
Post by pressy »
Theses guys are great to deal with, have used them for about 10 years now.
can make or get what ever you can think or that can be done.
see Jason
I-Trans gear and Transmisson
Christchurch
65 Treffers Road
Wigram Park
Christchurch
(03) 343 1460
Duralloy Gears
Greywacke Road Casebrook 8051
off johns road‎
UBZ
Post by UBZ »
Apprently you can just buy the 4.16 counter gear from lowrange offroad . and just use the other 410 and 413 gears out of the donner cases .
Saves having to have the hardened counter shafts machined and welded together .from memory they went through 3 cutting bits to do mine , so should be cheaper to just buy the gear off low range.
baby lobster will sort your high range road gearing for 31's but will do nothing to improve the low range gearing
Supa_zuka
Stropper
Post by Supa_zuka »
Do you think it would be cheaper to buy a new counter gear from the states than get mine machined?
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Last time I got one done in auckland it was $300.00
wayfastwhitee
Post by wayfastwhitee »
It costs around $1000 to get 4.9s from lowrange and do all the bearings and seals while your there. Just depends how much money you're willing to throw at it.
DieselBoy
Post by DieselBoy »
wayfastwhitee wrote:It costs around $1000 to get 4.9s from lowrange and do all the bearings and seals while your there. Just depends how much money you're willing to throw at it.
We're talking about Suzuki transfer case gears here spud, not Hilux diff's :D :D :D :D
wayfastwhitee
http://www.lowrangeoffroad.com/index.ph ... gears.html
not sure if you're joking or not?
BlakeJ
Post by BlakeJ »
If hes already got the other gears from the 413/410 cases you can email and ask lowrange for a price of just the counter gear (like UBZ said) its way cheaper than the whole set, would still reccomend doing bearings and seals but you can pick them up trade cheap as chips
v8rapid
Post by v8rapid »
i have 4.16 calmini gears in mine and have given them death and drive on road all the time too- i have 31" maxxis and 32"" simex for the ruff stuff and works out good, will do 22kph tapped out in 5th gear :shock:
Return to “Suzuki”
